SCE Bootup Problem
Gustavo Paiva Fri, 11/27/2009 - 05:17
Hi everybody,
This is an old post, but I have the same problem... somebody knows how to boot the SCE from the VxWorks console?
Gustavo.
gjaimes Thu, 02/04/2010 - 14:14
Hi Gustavo,
Did you get an answer to this problem?
I have the same problem !!!
Gustavo Paiva Fri, 02/05/2010 - 04:23
First you need is a file named "SEos"... I looked for this file in the download area of Cisco could not find it.
Then the procedure is very similar to others using VxWorks...
Gustavo.
miroslav.slavkov Wed, 06/30/2010 - 06:25
If you have a running box, you can extract the OS file and boot it with TFTP.
The file name is 'seos'.
russell.bean Fri, 09/30/2011 - 07:58
Hi, I have the same issue, but the network card doesnt boot, how can I get the management Ethernet interface to come up in the VX works boot mode so I can copy the seos file from another working device?
