VPN Connected but unusable
Nov 28th, 2008
I have an issue on some of our mobile laptops XP SP3 VPN Client 4.7. They can connect and auth. to our LAN, but nothing on the LAN is visable or accessable. When I show the ststus on the windows task bar and I try to access anything on the remote LAN I see no communications going through the VPN. It works fine on some of the laptops. The Windows configuration looks the same. Tried un-installing and re-installing but nothing changed.
JORGE RODRIGUEZ Mon, 12/01/2008 - 13:02
What is your RA server PIX ASA, Router?
1-Are you using the same VPN client on all the labtops?
2- Make sure you have NAT-T enabled see if makes any difference after.
ASA(config)#crypto isakmp nat-traversal 20
PIX(config)#isakmp nat-traversal 20
3- Look at the PIX/ASA ASDM logs when client
tries accessing LAN resources.
JORGE RODRIGUEZ Tue, 12/02/2008 - 09:13
Do you have NAT-T enabled?
look at your config
pix#show run | inc isakmp nat-traversal
if not configured use
pix(config)#isakmp nat-traversal 20
and have your vpn clients try connecting
