Throughput problem on AIR-PI21AG-E-K9
Answered Question
Nov 28th, 2008
I have configured a wireless LAN with a:
- WLC 4402 -25
- AIR-AP1121G-E-K9 converted to lightweight
- AIR-AP1121G-A-K9 converted to lightweight
- Client adapter AIR-PI21AG-E-K9
I have a problem in one floor of the building where there are 3 AIR-AP1121G-A-K9 and one AIR-AP1121G-E-K9: after connecting to the WLAN, the adapter client get a throughput of 54 mbits and it is connected to the nearest AP (AIR-AP1121G-A-K9) but after few minutes it roam to the AIR-AP1121G-E-K9 with a throughput of 1 mbits.
Please can you help e to fix this problem?
Thank you
Correct Answer by Scott Fella about 8 years 5 months ago
It sure can be... you want to at least keep standard. WLC and AP's on the same regulatory domain and client cards too. Depending on the regulatory domain, certain channels and TX levels change.
Overall Rating: 5 (1 ratings)
Scott Fella Fri, 11/28/2008 - 07:28
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Try to disable the lower data rate on the WLC. This will sometimes forces a client not to connect to a lower data rate, but some cards do have issues with this. Disable 1mbps, 2mbps and 5.5mbps and see if this fixes your problem.
nizar.houichi Fri, 11/28/2008 - 07:35
thank you for replying,
i would like to khnow if the regulatory domain can be the cause of the problem.
Thank you
Correct Answer
Scott Fella Sat, 11/29/2008 - 08:54
  • Hall of Fame,
    2017 Wireless
