firewall vlan-group: adding vlans to exisiting vlan-group
I have the following firewall vlan-group defined on my 6500
firewall vlan-group 3 2803,2805,2807
I need to add another vlan, say 2809 to this group.
Will this command:
firewall vlan-group 3 2809
overwrite or append the exisitng vlan-group. What would be the safest method to add this new vlan to the group.
Any suggestions would be appreciated.
Giuseppe Larosa Fri, 11/28/2008 - 06:41
  • Hall of Fame,
    Founding Member
Hello Sean,
I've given a look at one of my C6500.
the command allows multiline :
RT-xxx#sh run | inc vlan-group
firewall module 4 vlan-group 41
firewall vlan-group 41 3-9,11-14,97-99,200,201,400,405,410,415,420,425
firewall vlan-group 41 430-432,435,440,445,450,455,460,465,470,475,480,485
firewall vlan-group 41 490,531,532,600-602,605,606,610-612,615,630,644-648
firewall vlan-group 41 651,656,661,666,696-698,700-703,730,745-748,800,801
firewall vlan-group 41 901,902
RT-xxx
this is IOS
disk0:s72033-adventerprisek9_wan-mz.122-18.SXF14.bin
So I think you can add a line with the two new vlans without issues
Hope to help
Giuseppe
Giuseppe,
Thanks for the reply.
Just so that I understand if my current config is :
sh firewall vlan-group 3
Group Created by vlans
3 FWSM 2803,2805,2807
running the:
command will merely add this vlan to the exisiting group so that my output from the sh firewall vlan-group command will be as follows:
3 FWSM 2803,2805,2807,2809
What I am trying to avoid is running firewall vlan-group 3 2809 and the three existing vlans are removed from the group and replaced by 2809.
Thanks again,
Sean
Jon Marshall Fri, 11/28/2008 - 10:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sean
If you run "firewall vlan-group 3 2809" then it will just append it to the existing line. It will not overwrite your existing configuration. Promise :-)
Jon
Shiva Prasad Tue, 02/21/2012 - 15:12
Hi Jon,
Thanks, that was helpful, i would be greatful if you can help clear my doubt.
Is there a specific order to add a new vlan to the fwsm ? i added a new vlan to the firewall group but it does not show up in the system context. should i input the vlan config in the fwsm system context (interface vlan ) firts  and then add the vlan in the switch config ? the diocumentation that i could find is confusing.
Shiva
Farooq Razzaque Sat, 08/23/2014 - 08:42
Dear Team
We have a core switch in VSS with FWSM running with multiple contexts.
I need to create 5 new DMZ (interfaces) in FWSM server context
Currently my config shows like below, which includes three "firewall vlan-group" statements, each with a comma-separated list of vlan numbers:
firewall switch 1 module 4 vlan-group 1,2,3
firewall switch 2 module 4 vlan-group 1,2,3
firewall vlan-group 1  2,3,4
firewall vlan-group 2  5,6,7  (vlans for server context)
firewall vlan-group 3  8,9,10
My question is:  when I add the 5 new vlans, do I have to simply issue an additional "firewall vlan-group" statement with the five new vlan numbers, like this?
firewall vlan-group 2 30,40,50,60,70  (I need to add vlans in vlan-group 2)
In other words, will above command overwrite my existing list of vlans in vlan group 2 if I only add the five new vlans in vlan group 2 ?  I obviously don't want to lose connectivity by erasing all my existing vlans.
Or do I have to issue a new statement that includes ALL of the existing vlans and five new vlans, like this?
firewall vlan-group 2 [all previously existing vlans],30,40,50,60,70 (five new vlans)
I want to know if i typed the above command with existing vlan and the new vlans does it cause any issues to the running environment b/c i think with the above command existing vlans will also be pushed along with new vlans to FWSM again or this is not the case.
