Logging options
Nov 28th, 2008
I use Cisco 857 routers for internet access.
I want to use logging to keep a record of when the internet connection is active, so that if there is a problem when I am not around, I can look back through the log, and identify whether the internet connection was functioning correctly.
I am not familiar with the logging options, is there a simple way to do this?
nickc1976 Fri, 11/28/2008 - 07:02
Here is the output of my show logging command:
Router#show logging
Syslog logging: enabled (1 messages dropped, 0 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level critical, 0 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 90 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
Trap logging: level debugging, 94 message lines logged
Log Buffer (51200 bytes):
lejoe.thomas Fri, 11/28/2008 - 16:08
You'll need to configure the router for Syslog, which allows for logging messages to be sent a syslog server, which stores these messages and makes it easier for troubleshooting.
Assuming you have syslog (kiwi Syslog) running on a windows machine or a syslog daemon on UNIX in your network (X.X.X.X), configure logging on the 857
host - syslog server address
logging trap
level - limits the messages logged on to the system, such as debugging, informational etc.
johnlloyd_13 Sat, 11/29/2008 - 02:59
if you just want to enable local logging, go to global config mode and issue the logging buffered command. our routers are configured this way as an example:
logging buffered 4096 debugging
4096 is the minimum bytes configured and debugging is equal to level 7, which will include all syslogs from 0-6.
