Gatekeeper RAS QOS - Gateways and Gatekeeper
Nov 28th, 2008
I have been searching around trying to find a decent solution to the above, without much luck.
Is there an approach to setting the RAS QOS on gateways and gatekeeper. The default is 0x0 which is not good.
Using an ACL seems like a very clunky approach, is there any other way?
Marwan ALshawi Fri, 11/28/2008 - 18:47
try to put the foolowing command under the ras dial-peer
dscp siignalling cs3
hope this helps
scollinson Sat, 11/29/2008 - 02:49
Thanks, you are correct that does do some QOS. However there are still gaps on both the gateway and the gatekeeper.
I worked out a solution.
