h245 tunnel disable, how?
Answered Question
Nov 28th, 2008
Hello:
I have a ios (C2801-IPVOICE_IVS-M), Version 12.4(20)T1, RELEASE SOFTWARE (fc3)
And I want to disable the h245 tunnel.
This feature is disabled when the h245 tunnel disable command is issued.
I don't have this command.
anyone can say me why?
Antonio
Correct Answer by Stoyan Stoitsev about 8 years 5 months ago
This command is hidden so you won't see. Just type it
voice service voip
h323
h245 tunnel disable
BR,
Stoyan
Overall Rating: 5 (2 ratings)
Correct Answer
Stoyan Stoitsev Fri, 11/28/2008 - 10:13
  • Bronze, 100 points or more
voice service voip
h323
h245 tunnel disable
BR,
Stoyan
aherraez77 Sat, 11/29/2008 - 04:25
Hello:
You are right. Thanks. Can you say me why there are commander that are hidden?
