ACS 4.2 and and password change with IOS 12.4
Nov 28th, 2008
In Cisco Secure ACS, there is an option
to allow user(s) to change password when
logging into the routers. I am running
IOS version 12.4 and ACS 4.2 and it works
fine when I telnet into the router.
However, I can not get it to work when
I ssh into the router. I am running
IOS version 12.4. According to Cisco bug
ID CSCdy54970, this issue has been
resolved in version 12.3T. Well, I use
version 12.3(14)T11 and 12.4 and it is
not working for me.
Anyone know why? Thanks.
smallu Thu, 12/04/2008 - 19:00
Hi There,
When you say its not working, are you not even getting a prompt to change the password, when you just hit submit after entering the username, and nothing for password?
In that case, you need make sure the ACS has the UCP(User changeable Password) patch on it.
You can download this from CCO. Or open a TAC case for the same.
Hope this helps!
Srinivas.
