transcoder configuration for CCME and CCM integration
Nov 28th, 2008
CCME 4.1 integrate with CCM 4.2 as a h.323 gateway. Need to use g.729 for inter-site voip calls and g.711 for calls within local subnet. Now I configure a different region for CCME and choose codec g.729 to CCM region. Transcoder is configured only in CCME. Two sites can ring each other, but call drops as soon as it is picked up.
Should transcoder be configured in both CCM and CCME?
Should DSP resource for transcoder be available in both site gateways?
If inter-region codec is g.729, what is the codec with RTP streams sent from IP phone? Is the codec always g.711 with RTP streams sent from IP phone?
Thanks.
Marwan ALshawi Fri, 11/28/2008 - 18:44
hi there
first of all
i will assume all the phones cisco ip phones
ciscp ip phones can hndel xcodeing using its internal dsp for deffrent codecs in ur casee u dont need dsp
unless u want to route a call over the WAN link then to PSTN this way u must use trans coding on the terminating device which is the edge gateway
is the remote site phones rigistered with CME or CM?
also on the voip dial-peer put the command codec g729
which is the default on voip dial-peers
good luck
michaelzhq Sun, 11/30/2008 - 21:05
Thank you for the reply, Marwan.
Yes, all phones are Cisco ip phone.
remote site phones register with CME.
CCM site IP phone(G.711??)-->WAN(G.729)-->CME site-->CUE(G.711)
CUE only supports g.711, if the call coming from WAN is g.729, I think transcoding is necessary in CME.
Is region configuration only associated with
IP phone registering with CCM?
Marwan ALshawi Sun, 11/30/2008 - 21:23
for users useing cue they need transcoding
region only for users rigistered with CCM
also if u have gateway voice mail u can assign it region thorugh the device pool
good luck
