Cat6509E stuck in Rommon 1>
Nov 29th, 2008
Hi Netpro,
i am stuck in Rommon , my cat6 can not bootup. need your advice .
thanks.
regard
jack
Overall Rating: 3 (3 ratings)
vishwancc Sat, 11/29/2008 - 07:32
Hi Jack,
Where you doing some thin when it got into rommon.
I assume it is running hybrid IOS ,so is it rommon of SP or RP.
Give configregister value 0x2102 and reset.
Chao
Vishwa
ney25 Sat, 11/29/2008 - 20:29
Hi Vishwa,
this is sup 720 whereby someone itchy hand loaded wrong ios therefore causing switch cant boot up.
your reply will be highly appreciated.
thanks.
regards,
jack
ney25 Mon, 12/01/2008 - 02:34
Hi Viyuan,
thanks for your doc. it was really helpful but i dont know why ? after new ios loaded and boot path have been setup as well. somehow when i reload , it's went back to Rommon 1> again. :(
thanks.
jack
viyuan700 Mon, 12/01/2008 - 08:33
Hi Jack,
Can u please post the message it gives u before Rommon1 prompt
