MLA login failure issue
Nov 29th, 2008
I am facing a issue where i am not able to login when the MLA is enabled.
CCM Ver 4.1(3)
OS ver : 2000.2.4
OS upgrade : 2000.2.7
I have reffered the following link
http://www.ciscotaccc.com/voice/showcase?case=K13072010
http://www.ciscotaccc.com/voice/showcase?case=K32872551
http://www.ciscotaccc.com/voice/showcase?case=K92530324
But no success
Can anyone help me to resolve the login issue asap
tstanik Thu, 12/04/2008 - 14:43
These are the steps how to enable multilevel administration access in Cisco CallManager Administration prior to performing multilevel administration access configuration.
Step 1 After Cisco CallManager Administration has been installed, access Cisco CallManager Administration and Cisco CallManager Serviceability with the following URLs:
http:///ccmadmin
where specifies the IP address or name of the Cisco CallManager server.
Step 2 Choose User > Access Rights > Configure MLA Parameters.
The MLA Enterprise Parameter Configuration page displays.
Step 3 To change the Enable MultiLevelAdmin enterprise parameter, click the drop-down list box on the right and select True.
Step 4 Enter a new password at the prompt "New password for CCMAdministrator" and re-enter the password at the prompt "Confirm password for CCMAdministrator".
Step 5 Click Update.
I hope it may help you.
