NAT: Untranslate_hits
Answered Question
Nov 29th, 2008
hi,
On a 'show nat' display, what does the untranslate_hits mean as opposed to translate_hits.
thanks.
Correct Answer by Jon Marshall about 8 years 5 months ago
Actually yes it is possible and i may have been a little imprecise in my previous answer. From the Cisco command reference for ASA
counters-translate_hits provide counters for real to mapped address conversion and untranslate_hits provide counters for mapped to real address conversion
So even though NAT is a 2 way process i'm not sure what you are seeing with the counters is the 2 way conversion. An example might help
static (inside,outside) 195.177.12.1 192.168.5.1 netmask 255.255.255.255
If the connection is initiated from the inside host 192.168.5.1 i believe you will see this as a translate_hit because it is a real to mapped IP address translation.
If the connection is initiated from the outside to the 195.177.12.1 address i believe you will see this as an untranslate_hit because this is a mapped IP to real translation.
So i don't believe that for a connection you will get both a translate_hit and an untranslate_hit, rather i think it registers as either one or the other depending on which side the connection was initiated from.
Unfortunately i don't have an ASA to test this with but it would account for the uneven counters in your output.
Jon
translate_hits = counter for real to mapped IP addresses
untranslate_hits = counter for mapped to real IP addresses
In other words NAT is a 2 way process.
real IP = 192.168.5.10
Natted IP = 195.177.12.1
translate hit is when 192.168.5.10 is changed to 195.177.12.1
untranslate hit is when 195.177.12.1 is changed back to 192.168.5.10
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Sat, 11/29/2008 - 08:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
new_networker Sat, 11/29/2008 - 09:32
In my scenario, I have noticed that the translate hits are zero and untranslate_hits is non-zero. Is this possible. I am hitting the real IP from internet.
Correct Answer
Jon Marshall Sat, 11/29/2008 - 09:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
