With 4500s/4900s, they do not always respond to ping in rommon mode, so you will not be able to tell whether it's working or not.
Just make sure you have an arp entry in your laptop for the switch, and that the firewall on your laptop is turned off.
Also with these switches, you sometimes need to put in a default gateway, even if it's on the same local subnet.
Michael
