Prob DHCP: address allocation on ADSL interface C837
Answered Question
Nov 29th, 2008
Hello all,
I've started for first time configuration of my new ADSL router (Cisco 837)
The issue is the router coudn't get an IP adress from DHCP server of me ISP
You can see attached :
- sh ver
- sh ip int br
- sh run
& sh dhcp server: witch show no requests go out!!
Any advices
Correct Answer by lejoe.thomas about 8 years 3 months ago
Hi tarik,
Under you ATM interface, explicity specify the encap and protocol using
interface ATM0
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
After configuring this (issue shutdown and no shutdown to restart the interface)
Lejoe
Overall Rating: 3 (1 ratings)
lejoe.thomas Sat, 11/29/2008 - 16:44
  • Silver, 250 points or more
Hi Tarik,
Under dialer interface
remove ip address dhcp
and add
int dialer 0
ip address negotiated
this allows for the IP address of the dialer interface to be obtained via PPP/IPCP address negotiation
Lejoe
tarik.fakir Thu, 12/11/2008 - 10:32
Hello Lejoe,
I've done it but same result: no ip @ even interfaces up (atm 0 & dialer 0)!!
So need help again
# Sorry for delay I was away ;-)
Correct Answer
lejoe.thomas Thu, 12/11/2008 - 14:00
Hi tarik,
interface ATM0
pvc 0/38
Lejoe
