Multicast troubleshooting
mehsulsss
He everyone,
I am new to multicast and have a question regarding receiving the multicast. what is the easiest way to figure out if the data is being sent by the source or not. Any tips will be a big help.
mihanlin
To troubleshoot multicast, I have found the "show ip mroute count" command is a good place to start.
When you do this command, you will see the multicast groups, and statistics for the source address - which you mention you want to check.
Looking at the line beginning with "Source", you can see the forwarding statistics for the group. They are separated by "/" and are as follows:
Sent Packet Count/Packets sent per second/Avg Pkt Size/Kilobits per second
An example is below:
IP Multicast Statistics
2 routes using 1714 bytes of memory
1 group, 0.50 average sources per group
Forwarding Counts: Pkt Count/Pkts per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 224.12.12.12, Source count: 1, Packets forwarded: 4, Packets received: 4
Source: 10.1.1.4/32, Forwarding: 4/1/100/0, Other: 4/0/0
7 Replies 7
mihanlin
hi Mehdi,
Michael has provided good information to you. Just add other information.
Other: 4/0/0
If you're experiencing with RPF Failure then this command can show you.
Please check this link out:
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080093f21.shtml
Toshi
Great!! Thank you. In sparse mode,If I have a receiver trying to join the group, then I should see the count increase which means that the source is sending the stream for that particular group. If I don't see the count increase which will mean that the the source is not sending the stream for that group. Correct? Also, if I am in sparse mode, and have a receiver on my side, what will this indicate (*,g) & (s,g)?
Thanks again.
Mehdi,
There is a few things to consider.
- What is your topology like?
- Do you see the source (s,g) on the RP?
- Do you see that there is a receiver (*,g) on the RP?
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Topology is that I have two routers receiving the stream. I do have receiver trying to join the group and do see (*,g). In some stream is working fine and I do see the (s,g) but the others I only see (*,g). I did the ip mroute count and I see no packets and I even tried to do ip igmp join-group (Group ip) and still no luck. I think I am not receiving the group from the source just making sure that is the case.
Thank you
hi Mehdi,
We have to know exactly what the topology looks like. One is working fine. Another one is not? Have you correctly configured the RP? To make sure that the RP-C is advertiseting the correct group. To make a bit more clear on what's happening. Would you please post the configuration,excluding sensitive information?
Toshi
Thank you all. I think I have the answers to my problem. It sure was a great help.
Mehdi
