FWSM question
Nov 30th, 2008
our customer has a switch 6500 with 2 FWSM modules .
i need to ask about the following :
-can i configure the two modules for failover although the two modules in the same chassis or not ???????
- Is the FWSM support VPN or not???
regards
mohamed
Marwan ALshawi Sun, 11/30/2008 - 02:17
hi mohamed
You can place the primary and secondary FWSMs within the same switch or in two separate switches
http://www.cisco.com/en/US/docs/security/fwsm/fwsm31/configuration/guide/fail_f.html#wp1140822
* The FWSM does not support Virtual Private Network
(VPN) termination except for use in management, whereas the PIX, ASA, and IOS-based
devices all have that capability.
good luck
hope this helpful
