"Monitoring through AUX port"
Nov 30th, 2008
I've a router with LAN address configured on Eth0. I have to attach a system to aux port and have to monitor the aux port when the port is down..I want monitor the port with the ping utility...I want to assign to aux port an IP address, with routing enabled..
How is possible that?
Thank you for your support.
Best regards.
Overall Rating: 2 (2 ratings)
Giuseppe Larosa Mon, 12/01/2008 - 00:41
Hello Massimiliano,
the document provides the configuration on the router side.
You need to find the right cable setup to make it working if the other side in your case is a different device.
Hope to help
