Cisco PIX 6.35 issue
Nov 30th, 2008
Dear All,
Refer from cisco link http://www.cisco.com/en/US/docs/security/asa/migration/guide/pix2asa.html
that a software can change pix 6.x config to 7.x. I try to transfer the running config to
tftp server from a PIX 6.35 version but it is fail, any one can help me ?
P.S. My tftp server can ping to pix firewall each other, also tftp server already open.
ITB5P02# copy running-config tftp
Usage: copy capture:<capture-name> tftp://<location>/<pathname> [pcap]
copy http[s]://[<user>:<password>@]<location>[:<port>]/<pathname>
flash[:[image | pdm]]
copy tftp[:] flash[:[image | pdm]]
andrew.butterworth Sun, 11/30/2008 - 07:57
With PIX OS 6.x you need to use the 'write net' command:
write net 10.1.1.1:pixconfig.txt
The copy command is only good for copying new PIX OS or PDM images with 6.x.
Andy
