DBConnection0 registry not found
Nov 30th, 2008
trying to convert sip phone back to sccp:
in following the instructions in cisco document 'Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the
Reverse Process' it says:
'If your current SIP image is 4.x or earlier, complete these steps in
order to convert to the desired SCCP images 5.x or earlier:
1.. Run the executable file in order to install the SCCP software.'
so I tried to run cmterm-7940-7960-sccp.8-0-1.exe and I got a box saying:
'DBConnection0 registry not found. Setup will not continue.'
I did a search on google and read that this exe would not run on a PC. This is confusing. If it won't run on a PC, what is one supposed to do with it? Thanks for any help.
Overall Rating: 5 (1 ratings)
Jaime Valencia Sun, 11/30/2008 - 08:25
  • Cisco Employee,
  • Hall of Fame,
    2011
you're supposed to run in on the CCM server since it's going to modify a couple of things in the DB
if you read the README it will tell you to install on the server
java
if this helps, please rate
