Fax suppport with cisco unity using router 2821
Nov 30th, 2008
What fax features are do able and what features are not doable in exisitng router. Please find the attached sh version of the router configuration. I want to confirm with you that can i use voice gateway router with cisco unity to send fax inbound and outbound perfectly and cisco support officially.Because i found most of the people complaining unity(4.2) fax integration with router but with third party integration it will work fine.
