why clear counters eth0 does not clear all counters
Nov 30th, 2008
hi all
i have switch
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA2, RELEASE
i give command clear counters fa0/24
and it did clear all the counters
as shown below
h int fa0/24
FastEthernet0/24 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0013.7f5e.f218 (bia 0013.7f5e.f218)
Last input 00:00:07, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:07:48
Queueing strategy: fifo
Output queue: 0/40 (size/max)
53 packets/sec
724 packets input, 170794 bytes, 0 no buffer
Received 184 broadcasts (0 multicast)
0 watchdog, 109 multicast, 0 pause input
805 packets output, 114378 bytes, 0 underruns
now i did command
sh controllers ethernet-controller fa0/24
dstc-sw#sh controllers ethernet-controller fa0/24
Transmit Receive
1058324712 Bytes 3643036231 Bytes
4744246 Frames 4837184 Frames
769059 Multicast frames 0 FCS errors
123655 Broadcast frames 328756 Multicast frames
0 Pause frames 87284 Broadcast frames
27297 Single defer frames 0 Control frames
0 Multiple defer frames 0 Pause frames
6021 1 collision frames 0 Unknown opcode frames
1187 2-15 collisions 0 Alignment errors
0 Late collisions 0 Length out of range
0 Excessive collisions 0 Symbol error frames
8466 Total collisions 0 False carrier errors
0 Control frames 0 Valid frames, too small
0 VLAN discard frames 0 Valid frames, too large
0 Too old frames 0 Invalid frames, too small
0 Tagged frames 0 Invalid frames, too large
0 Aborted Tx frames 0 Discarded frames
Transmit and Receive
3140098 Minimum size frames
2034612 65 to 127 byte frames
689154 128 to 255 byte frames
552983 256 to 511 byte frames
464197 512 to 1023 byte frames
2700474 1024 to 1518 byte frames
0 1519 to 1522 byte frames
it still shows counters on port fa0/24?
any answer why counetrs are still not cleared.
Overall Rating: 5 (2 ratings)
mahesh18 Sun, 11/30/2008 - 09:33
then i did command
fdstc-sw#clear controllers ethernet-controller fa0/24
fdstc-sw#sh controllers ethernet-controller fa0/24
Transmit Receive
5266 Bytes 4574 Bytes
72 Frames 70 Frames
14 Multicast frames 0 FCS errors
0 Broadcast frames 5 Multicast frames
0 Pause frames 4 Broadcast frames
1 Single defer frames 0 Control frames
0 1 collision frames 0 Unknown opcode frames
0 2-15 collisions 0 Alignment errors
0 Total collisions 0 False carrier errors
129 Minimum size frames
11 65 to 127 byte frames
0 128 to 255 byte frames
10 256 to 511 byte frames
2 512 to 1023 byte frames
0 1024 to 1518 byte frames
now all are cleared.
i want to know what is difference between clear counters and clear controllers ethernet-controller fa0/24
command
thanks
Richard Burts Sun, 11/30/2008 - 13:51
Mahesh
The clear counters command clears the interface counters while the clear controllers ethernet-controller clears the underlying controller. It is a bit difficult to explain the difference between the interface and the ethernet controller. But I would suggest that the interface counters are more oriented to the software that manages the interface and the ethernet controller is the underlying hardware that runs the interface.
Rick
mahesh18 Mon, 12/01/2008 - 08:34
Hi rburts
thanks for reply.
so every switch port has interface counters
and underlying controller?
what is underlying controller is there any
documentation i can read?
mAny thanks
mahesh
Jon Marshall Sun, 11/30/2008 - 15:37
Mahesh
Are you sure you have pasted the full ouput of "sh int fa0/24" because from the command reference for 12.1(22)EA2 here is the equivalent output
Switch# show interfaces fastethernet0/1
FastEthernet0/1 is up, line protocol is down
Hardware is Fast Ethernet, address is 0005.7428.09c1 (bia 0005.7428.09c1)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed
input flow-control is off, output flow-control is off
Last input never, output 4d21h, output hang never
Input queue:0/75/0/0 (size/max/drops/flushes); Total output drops:0
Queueing strategy:fifo
Output queue :0/40 (size/max)
1 packets input, 64 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
1 packets output, 64 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
Notice that there are lines that are not in your output such as
I agree with Rick in that the "sh controllers ethernet-controller ... " command is reading the counters directly from the underlying hardware.
When you use "sh interface fa0/24" what you see is a 5 minute summary derived from the underlying hardware counters. You can clear these counters to reset the summary counters but the underlying counters they are derived from are still there.
At least that is what i think you are seeing, and it seems to make sense.
Jon
mahesh18 Mon, 12/01/2008 - 08:29
Hi jon
here is complete output of command
fdstc-sw#sh int fa0/24
MTU 1500 bytes, BW 10000 Kbit, DLY 100 usec,
Half-duplex, 10Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
Last input 00:00:35, output 00:00:01, output hang never
Last clearing of "show interface" counters 23:12:02
5 minute input rate 1000 bits/sec, 2 packets/sec
5 minute output rate 1000 bits/sec, 2 packets/sec
428080 packets input, 301645045 bytes, 0 no buffer
Received 29337 broadcasts (0 multicast)
0 watchdog, 19599 multicast, 0 pause input
400366 packets output, 111351437 bytes, 0 underruns
0 output errors, 759 collisions, 0 interface resets
0 babbles, 0 late collision, 1990 deferred
