Warning message
ACE questions
Nov 30th, 2008
  • Bronze, 100 points or more
1. What is the diff btwn none 301 and 302 on
webhost-redirection https://%h 301
webhost-redirection https://%h 302
2. Since I have redirection from 80 to 443, which cookie methods is best to use (sticky, Source IP Sticky, or SSL session ID sticky)?
3. I'm currently using SourceIP-Sticky, below is my current configs, is it correct?
rserver redirect HTTPS-REDIRECT
webhost-redirection https://%h%p 301
inservice
serverfarm redirect HTTPS-REDIRECT
rserver HTTPS-REDIRECT
inservice
sticky ip-netmask 255.255.255.255 address source SRCIPSTICKY
timeout 60
serverfarm DATASOLUTIONS
policy-map type loadbalance first-match L7_POLICY
class class-default
serverfarm HTTPS-REDIRECT
policy-map type loadbalance first-match L7_POLICY_SSL
class class-default
sticky-serverfarm SRCIPSTICKY
policy-map multi-match L4_POLICY
class MATCH_VIP
loadbalance vip inservice
loadbalance policy L7_POLICY
loadbalance vip icmp-reply active
loadbalance vip advertise active
class MATCH_VIP_HTTPS
loadbalance policy L7_POLICY_SSL
litrenta Mon, 12/01/2008 - 07:33
  • Cisco Employee,
1. none will default to 302 so choices are 301 or 302.
2. Since you are not offloading ssl on the ace and just passing it through to server best sticky method would be source ip. In this scenario your only choices are source ip or ssl session id. Stay away from ssl session id because internet explorer since 5.0 renogiates it every 2 minutes.
aamercado Mon, 12/01/2008 - 07:38
Thanks for the quick responce but,
what does 301 mean?
What does 302 mean?
Syed Iftekhar Ahmed Mon, 12/01/2008 - 12:13
  • Blue, 1500 points or more
301-- permanently moved
302-- temporarily moved
These are particularly useful for search engines like Google, which in case of 301 will index the redirected page & for 302 will index the original page.
Syed Iftekhar Ahmed
