DMZ config! How to do? Easy question for experts! (ASA 5510
Nov 30th, 2008
Dear All
I would like to add a DMZ and VPN to inside network to my ASA5510 configuration, but I'm not sure about the correct way to achieve my goal (I'm a newbie).
I'll rate your post and promise to send to the best answer a traditional Christmas gift from my country, I'm sure that you will be pleased with it!:)
Goal:
1- I want to put a Microsoft Exchange Server 2007 (EDGE Role- Front-Side e-mail server) on a new DMZ.
2- VPN access to inside network.
1.1 This e-mail server (name EDGESRV) in the DMZ needs the following configurations:
Access to EDGESRV from Internet (SMTP)
 Access from EDGESRV to internet (SMTP)
 Access from internal network to EDGSRV ports: 25(SMTP), 50389 (Ldap), 50636(Secure Ldap) and port 3389 (TCP for terminal services)
ROUTER :
Interface Serial IP: 195.22.12.46/30
IP route 0.0.0.0 0.0.0.0 195.22.12.45
Interface Ethernet f0/0: IP 195.22.26.17/29 (connect to router)
ASA NETWORK
Interface External e0/0 :IP 195.22.26.18/29 (connect to router)
Interface internal: e0/1: IP 10.10.100.1 mask 255.255.252.0
Interface DMZ: e0/2 : IP 10.10.150.1 mask 255.255.255.0 (not implemented yet)
ASA Configuration (actual)
ASA Version 8.0(2)
interface Ethernet0/0
nameif Interface_to_cisco_router
security-level 0
ip address 195.22.26.18 255.255.255.248
interface Ethernet0/1
nameif Int_Internal_domain
security-level 100
ip address 10.10.100.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxxxxxxxxxxxx encrypted
boot system disk0:/asa802-k8.bin
ftp mode passive
clock timezone WEST 0
clock summer-time WEDT recurring last Sun Mar 1:00 last Sun Oct 2:00
dns domain-lookup Interface_to_cisco_router
dns domain-lookup Int_Internal_domain.com
dns server-group DefaultDNS
name-server 195.22.0.136
name-server 195.22.0.33
domain-name domain.com
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list Interface_to_router_Cisco_access_in extended permit object-group TCPUDP any any eq domain
access-list Interface_to_router_Cisco_access_in extended permit tcp any any eq www
pager lines 24
logging list Registo_eventos_william level emergencies
logging list Registo_eventos_william level emergencies class vpn
logging asdm informational
logging recipient-address [email protected] level critical
mtu management 1500
mtu Interface_to_router_Cisco 1500
mtu Int_Internal_domain 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (Interface_to_router_Cisco) 101 interface
nat (Int_Internal) 101 10.10.100.0 255.255.255.0
nat (Int_Internal) 101 0.0.0.0 0.0.0.0
nat (management) 101 0.0.0.0 0.0.0.0
access-group Interface_to_router_Cisco_access_in in interface Interface_to_router_Cisco
route Interface_to_router_Cisco 0.0.0.0 0.0.0.0 195.22.26.17 1
access-list Int_Internal_access_in extended permit tcp any any
access-list Int_Internal_access_in extended permit udp any any
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.10.100.0 255.255.255.0 Int_Internal_domain
http 10.10.10.0 255.255.255.0 management
http 195.22.26.16 255.255.255.248 Interface_to_router_Cisco
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
Kind Regards
MP
Overall Rating: 5 (2 ratings)
JORGE RODRIGUEZ Sun, 11/30/2008 - 14:53
  • Green, 3000 points or more
Mario,
I think you have much more to go but this is a start, I don't think I have cover everything .. others in netpro may add to this.
Use this example, Configuring Mail server on DMZ http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806745b8.shtml
You can configure RA VPN server using/creating in ASA5510 Local user database
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008060f25c.shtml
or configure RA VPN server using IAS RADIUS-Windows AD for authentication
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806de37e.shtml
-Access to EDGESRV from internet on port smtp if you have spare public IP you can create a one-to-one NAT for this server and create
inbound access rules to allow access on SMPT from outside internet.
If you do not have spare public IPs for a one-to-one nat on this server you can use ASA outside interface static PAT.
Example : static (dmz,outside) tcp interface smtp netmask 255.255.255.255
-Access from EDGESRV to internet (SMTP)
You need to PAT DMZ network, if EDGESRV does not have one-to-one static NAT
typical scenario
global (outside ) 101 interface
nat (dmz ) 101 0 0
or
nat (dmz) 101 <255.255.255.255>
also for the MAIL Server, if you are using DNS server from your inside network you need acl to allow traffic from MAILserver DMZ to DNS in inside network.
-Access from internal network to EDGSRV ports: 25(SMTP), 50389 (Ldap), 50636(Secure Ldap) and port 3389 (TCP for terminal services)
from low sec level 0 to high sec level access is permited by default, you do however need to create static nat to allow comm between inside and dmz
in your scenario if you have 192.168.1.0/24 for inside interface network you would then create something like this.
static (inside,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
Observation -
I see you have interface Ethernet0/2 free, I assume you will probably be using this interface for your DMZ, I would advice to use subinterfaces and use dot1q in order to scale your DMZs in the future.
Look this link for reference on working with subinterfaces
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/intrface.html
Rgds
Jorge
MARIO PAIVA Mon, 12/01/2008 - 07:37
Hi Jorge
Thanks for your detailed answer.
So here are my issues:
Yes I do have spare public IP, so which is the correct config for this scenario:
Spare IP Address: 195.22.26.19 mask - 255.255.255.248.
So the Interface DMZ: e0/2 will be : xxx.xxx.xxx.xxx ?
And the IP address for the Server?
Thanks in advance for your cooperation.
Kind Regards
MP
JORGE RODRIGUEZ Mon, 12/01/2008 - 09:46
You need to creatre dot1q trunking between asa ethernet0/2 and your DMZ switch in order to create subinterfaces in ASA and respective VLANs in switch
for example: say you call DMZ network DMZ1 and give it VLAN 100 in switch
1 - In dmz switch create vlan for DMZ1
first allocate a port on DMZ switch to connect to ASA E0/2 interface, say you have 3550 switch and picked port 48 for trunk port.
switch#vlan database
switch#vlan 100 name DMZ1_10.10.150.0/24
switch(config)#interface fe0/48
switch(config-if)#Description Connection to ASAFe0/2
switch(config-if)#Switchport trunk encapsulation dot1q
switch(config-if)#switch port mode trunk
switch(config-if)#switchport trunk allowed vlan 100,200,300 etc...
switch(config-if)#speed 100
switch(config-if)#duplex full
switch(config)#exit
then allocate a port on the switch for your MAIL server and put it in VLAN 100
etc..
on asa
asa(config)#interface ethernet0/2
asa(config-if)#no shutdown
asa(config-if)#speed 100
asa(config-if)#duplex full
asa(config-if)#exit
asa(config)# interface ethernet0/2.100
asa(config-subif)# vlan 100
asa(config-subif)#Description DMZ1_NETwork
asa(config-subif)#nameif DMZ1
asa(config-subif)#security-level 50
asa(config-subif)#ip address 10.10.150.1 255.255.255.0
if in future you need to create another DMZ network simply iterate the above process
for for different vlan# and allow new vlan in switch trunk port.
for your Mail server your static will look as: assuming 10.10.150.100/24 is your mail server IP.
static (DMZ1,outside) 195.22.26.19 10.10.150.100 netmask 255.255.255.255
then create inbound access rules with appropriate tcp ports .
Jorge
PLS rate any helpful post
