ASA error message
Nov 30th, 2008
I keep getting this error message 715039 after I upgrade my ASA ver to 8.04.
Error message:-
%ASA-7-715039: Group = XXX, Username = sXXXe, IP = XXX, Unexpected cleanup of tunnel table entry during SA delete.
It seemed that every users disconnect will trigger this alert when I look to the Cisco website it says that if this message occurs too frequently there maybe a bug. Anyone can help? Thanks
torchris Tue, 12/02/2008 - 08:57
There is a tool called the software bug toolkit on www.cisco.com, you can look for it on the search field. With this tool, you can find bugs with their workaround pretty easy with a couple of details.
