Point to Multi-Point WAN Solutions
Nov 30th, 2008
Hi, I need to connect a HQ office to 3 branch offices over point-to-point T1's.
I know I can use frame relay for this but what other way will work? Is it possible to have 3 routers talking to 1 router with 3 WIC-1DSU-T1 cards, each with its own P2P T1? Any ideas are appreciated! Thanks, Mitchell
harish.ab Mon, 12/01/2008 - 03:08
Hi Mitchell,
If you are using seperate interfaces, u need to have 3 seperate lines too. why dont you think about some MPLS solution if your service provoder supports. Then you can acheive full meshed connectivity
Harish
Joseph W. Doherty Mon, 12/01/2008 - 04:47
"Is it possible to have 3 routers talking to 1 router with 3 WIC-1DSU-T1 cards, each with its own P2P T1?"
Believe the answer is yes.
Besides Harish's suggestion of MPLS, and yours of frame-relay, both ATM or Internet VPN is also possible.
