Topology Services not running
Nov 30th, 2008
I have another problem for CM Topology Services. Even though with specified version of java plug in on the server, Topo Services is not able to run. Java logo is also not loading. Please advise. Thanks!!!
Yi Shyuan
Joe Clarke Sun, 11/30/2008 - 21:21
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Please post a screenshot illustrating the problem. What version of Java do you have loaded on the client?
jeeyishyuan Sun, 11/30/2008 - 21:31
Hi jclarke,
The java plug in version is jre-1_5_0_13-windows-i586-p_withvbj.exe.
Joe Clarke Sun, 11/30/2008 - 21:32
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Assuming you have no other versions of Java installed, then this is fine. I would still like to see a screenshot to see what you're seeing.
jeeyishyuan Sun, 11/30/2008 - 21:33
Hi jclarke,
The screen shots showed the windows prompted when Topology services is launched. After saving the .jnlp file. No other window is prompted.
Joe Clarke Sun, 11/30/2008 - 21:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It looks like you've associated JNLP files with a Save As action. You can either fix the browser association so that Java is launched, or simply double-click on the downloaded Topolopgy_Services.jnlp file.
Carlos Morais Thu, 12/22/2011 - 06:33
Hi, jeeyishyuan.
If you want to avoid saving the .jnlp file, try to go to Tools > Internet Options > Advanced > Security tab and confirm that the option "Do not save encrypted pages to disk" is disabled. If it is not, disable it and your problem should be solved. Anyway, you can always double-click the Topolopgy_Services.jnlp file as Joseph Clarke suggested.
