Inter Cluster Trunk
Answered Question
Nov 30th, 2008
Hi All,
I have two clusters A & B with different Call Manager Versions.I want the calls should be established between two clusters.
what all is required to be done i.e. min. basic config in call managers /any hardware is required ?
regds,
aman
Correct Answer by Jaime Valencia about 8 years 8 months ago
configure an ict on each cluster and point to the ip, configure the inbound css on ict. Versions do not matter. Then use the ict on route patterns
Java
Overall Rating: 5 (2 ratings)
asif.rehman Sun, 11/30/2008 - 21:31
I assume that you dont have a GK in this scenario. Create a intercluster trunk on Cluster A (No GK Controllerd) and a Router Pattern pattern pointing phones in cluster B. follow the same for Cluster B.
amansoi_5 Sun, 11/30/2008 - 21:44
Hi Asif,
That's right we do not have any Gatekeeper.
Further,if you could detail us the exact config to be done in CCM ,it would be great.What I undertsand is that CM version is not any limitaion on ICT?
regds,
aman
Correct Answer
Jaime Valencia Sun, 11/30/2008 - 21:57
  • Cisco Employee,
  • Hall of Fame,
    2011
Java
