6500-CATSwitch-Unable to add syslog{Urgent}
Nov 30th, 2008
Hi All
I am trying to delete on syslog server(20.1.128.105) and add new syslog server(20.1.36.144)
the problem is whenei give show config i see still the same oldsyslog server 20.1.128.105 unable to find new one
can u suggest me where is the worng
regds
Adhi
LOGS Pasted below
clear logging server 20.1.129.105
System logging server 20.1.129.105 removed from system logging server table.
DC-6513-2> (enable) 2008 Dec 01 05:22:29 %SYS-6-CFG_CHG:Global block changed by telnet/
DC-6513-2> (enable) set logging server 20.1.36.144
20.1.36.144 added to system logging server table.
ATL-2100-DC-6513-2> (enable) 2008 Dec 01 05:22:49 %SYS-6-CFG_CHG:Global block changed by telnet/
JORGE RODRIGUEZ Sun, 11/30/2008 - 23:09
Are you trying to delete 20.1.128.105 or 20.1.129.105 , Im sure is typo?
from the log you posted seems 20.1.129.105 has been removed , and 20.1.36.144 has been added.
from that switch can you post the output of show config | inc logging
Rgds
Jorge
adhityakarthik Mon, 12/01/2008 - 00:06
HI
Thanks very much for your reply yes it is 20.1.129.105
Please find the output of switch
DC-6513-2> (enable) sh conf | in logging
set logging server enable
set logging server 20.1.129.105
set logging server 20.1.129.111
set logging server 20.1.128.228
set logging level gl2pt 2 default
set logging level diag 2 default
DC-6513-2> (enable)
adhityakarthik Mon, 12/01/2008 - 22:42
IOS version is below
WS-C6513 Software, Version NmpSW: 8.5(2)
System Bootstrap Version: 7.1(1)
System Web Interface Version: Engine Version: 5.3.4 ADP Device: Cat6000 ADP Version: 8.0 ADK: 49
System Boot Image File is 'bootflash:bootflash'
System Configuration register is 0x2
Hey i am able to see the configured syslog server by using below commands
DC-6513-2> (enable) sh logging noalias
Trace logging: disabled
Logging buffer size: 500
timestamp option: enabled
Logging history:
severity: warnings(4)
Logging console: enabled
Logging telnet: enabled
Logging server: enabled
{20.1.36.144, 20.1.36.143, 20.1.128.228}
server facility: LOCAL4
server severity: information(6)
Current Logging Session: enabled
Callhome Functionality: disabled
Callhome Severity: LOG_CRIT(2)
I think it could be problem with IOS , but the IOS with lesserver version dont have this problme
Any commnets
regds
Adhi
