NAC Login Delay
Nov 30th, 2008
We are running a NAC appliance and are currently using it solely for access control, no posture assessment etc. It seems take about 20 seconds to login after you click 'login'.
Can this be sped up?
owillins Fri, 12/05/2008 - 11:52
Make sure you have enabled the group policy option "Always wait for the network at computer startup and login" on the workstations. There may be possible for dhcp server is sending ip address twice and that is taking time as well.
flitcraft33 Fri, 01/30/2009 - 09:12
If you are in an Active Directory domain make sure this policy is coming from the domain and use the policy modelling tool to make sure it ends up being applied.
shangde001 Mon, 03/09/2009 - 00:53
