IPMA
aftariq
CTI route point is not registering. I was wondering if it was because of the CSS. I ran the wizard initially but i am not sure if i generated the CSS correctly. Can some onetell me which partitions should be in which CSS. or rather which should not be. Currently there are two CSS controlled by IPMA everyone and Manager. All partitions are in both CSS including the route-point partition.
Jaime Valencia
this diagram shows how you should have them:
Figure 23-8 Unified CM Assistant Proxy Line Mode Dial Plan Example
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/cmapps.html#wp1043992
java
if this helps, please rate
java
Jaime Valencia
java
java
