Problem with acces-list permit and deny
Dec 1st, 2008
Dear All,
Please help me to solve problem as below!!!
I had Cisco switch 3560 and i did inter-Vlan on this switch. So i was create 3 vlan( Vlan10,20 and 30) and was configure
access-list all 3 vlan .
let me tell u what i want:
1.On Vlan 10: Vlan10 can access vlan 20 and Vlan30.
2.On Vlan 20 : cannot access Vlan 10 and Vlan 30.
3.On Vlan 30 : cannot access Vlan 10 and vlan20
as configuration as above it doesn't work Could you correct on this comand?
Best Regards,
Rechard
Marwan ALshawi Mon, 12/01/2008 - 01:30
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
the only way u can configure it by using the established ACL this way the returne traffic from vlan 10 will be permited
k.cherian Tue, 12/02/2008 - 16:54
Hi David,
On Vlan 10, since we are allowing access to all other Vlans, we would not need any ACLs on that Vlan.
For Vlan 20 and 30, we can configure and apply a standard ACL that will deny any packets with a destination address to either of the other Vlans.
For example on Vlan 20, you will create an ACL with ACEs as follows:
deny ip any
deny ip any
Once done, you can apply this group on to the Vlan interface.
Hope this helps.
-/ KC
ganeshhiyer Tue, 12/02/2008 - 21:47
Hi rechard,
Can you share the configuration of VACL what you have deployed in the interface of each vlan.
Ganesh.H
