Need to advice( VPN diagram )
Dec 1st, 2008
Dear all,
Every one please help me to advice diagram how can i design......
Right now i had Cisco ASA 5520 ( at HQ office ) it is using VPN connection ( 2 ISP) i mean 2 outside interface .
and my branch i had ASA 5505 2 units and i had 2 ISP at my branch so i would like to use redundancy and my branch .....
how can i design and configure on ASA....
if you not clear i will more detail you on this....
Hope some one reply me ........
Davy Ad Mon, 12/01/2008 - 04:18
Hi Rechard,
The best bet is Active /passive , but i think it will be better only if both are of the same model (e.g ASA 5520 to ASA 5520)
DAK
rechard_david Mon, 12/01/2008 - 17:34
Hi DAK,
It not the same model..... at HQ i use ASA 5520 and at the branch i use ASA 5505 (2units).
So how can i do ?
Please help to advice how can i do ?
Best Regards,
Rechard
