Looking for encryption for ethernet link between 2 firewalls
Dec 1st, 2008
We have an ASA 5500 linked to another site about a mile away (via extended ethernet fibre). We need some encryption on this link - typically AES. Is the only way to encrypt to use IPSEC/VPN Or can we encrpty the traffic in "less complex" way. Issues of performance matter too as there will be voice and time-critical apps running over this line too
cisco24x7 Mon, 12/01/2008 - 05:48
  • Silver, 250 points or more
Not entirely true. You can place a hardware
crypto on both ends. Think of it like
encrypting the microwave signal. Doesn't have
to be VPN.
peter-net Mon, 12/01/2008 - 05:56
OK - I cant do a hardware option. So if I discount that - we are saying - either go for VPN solution - or not have encryption between the 2 locations ?
cisco24x7 Mon, 12/01/2008 - 06:20
You can approach the problem this way:
Option #1: VPN
Option #2: encrypt at the application level
with either SSH or SSL encryption
Either way, the communication will be secure.
