ASA5520 Local CA does it support CVPN RA client
Answered Question
Dec 1st, 2008
Hi There,
Can anyone confirm if the Local CA in ver 8.x can act as the CA for Cisco VPN(CVPN) IPSec RA clients as well as SSL VPN (browser and client based) connections.
Correct Answer by Davy Ad about 8 years 3 months ago
Hi Jim,
Yes CVPN should be able to use the AS v8.x "Local" Certificate Authority.
DAk
Overall Rating: 5 (1 ratings)
Davy Ad Tue, 12/02/2008 - 08:52
Hi Jim,
Are you trying to know if ASA5520 ver8.x support both SSLVPN & IPSEC.
The answer is YES!
DAK
jim-bell Tue, 12/02/2008 - 15:40
Thanks Dak,
We were looking to confirm that the Cisco VPN client (CVPN) can use the ASA v8.x "Local" Certificate Authority (CA) for certificate enrollment. We currently use ASA v7.2 and the CPVN clients obtain their certificate from a Cisco IOS CA.
Correct Answer
Davy Ad Wed, 12/03/2008 - 01:20
Hi Jim,
DAk
kbelachew Wed, 08/17/2011 - 13:04
Davy,
Can you please point me to relevant configuration guide if you know to configure IPSec Remote Access VPN with ASA local ca server?
Kebadu
