cisco equivalent for porterrshow
Dec 1st, 2008
Hi Guru's,
Is there a equivalent to porterrshow command available in Brocade FOS.
Its extremely difficult to isolate SFP issues with sh int fc. Since this display port by port info and is equivalent to portshow in Brocade FOS.
Appreciate if someone can jot down the first few commands required to troubleshoot issues on the MDS platform.
Thanks Everyone.
Overall Rating: 3 (1 ratings)
peter.ooms Mon, 12/01/2008 - 13:14
Do you want/mean: show interface brief
That command quickly indicate port status.
Using: show interface transceiver
displays transceiver states.
Beyond the normal for analysis, you can attach the module (attach module x) for the port where the problem is located and then use:
show port-config internal link-events
to display details flow of states.
Also details to de port relevant states could help (in attache module mode):
show logging onboard error-stats port x
Keep in mind and use your common sense for errors. No light/cable is no connection and so on.
bijucyborg Mon, 12/01/2008 - 20:31
Hi Peter,
Thanks a ton for the response. I will try the attach module today.
Correct me if I'm wrong show interface brief does not give me a overview of the errors.
This is the o/p of porterrshow, do you think its useful command??? Let me know your views.
XXXXXX> porterrshow
frames enc crc too too bad enc disc link loss loss frjt fbsy
tx rx in err shrt long eof out c3 fail sync sig
0: 2.7g 3.8g 0 0 0 0 0 0 0 4 1 22 0 0
1: 2.4g 3.8g 0 0 0 0 0 0 34 7 0 186 0 0
2: 965m 3.1g 0 0 0 0 0 7 30 23 23 697 0 0
3: 1.0g 1.1g 0 0 0 0 0 10 28 8 7 194 0 0
4: 146 104 0 0 0 0 0 0 14 0 0 64 0 0
5: 1.6g 98m 0 0 0 0 0 7 1 0 6 9 0 0
6: 3.6g 585m 0 0 0 0 0 2 1 0 6 9 0 0
7: 0 0 0 0 0 0 0 0 0 0 0 2 0 0
stephen2615 Wed, 12/03/2008 - 00:52
There is no equiv for porterrshow. However, it you were to consider portstatsshow or portstats64show, the cisco sho int shows something very similar.
porterrshow is nice for a very quick look at your switch.
One thing you might miss is fabstateshow.
Stephen
Trending Topics: Storage Networking
