NetBios SMB Packets do not pass
Dec 1st, 2008
I have configured IPSec VPN, and connections succeed, but the traffic is too slow.
I have realized that when the client access to a shared folder server, it succeeds, but when I click on right button to see properties on a file, it takes at leas 3 min to have the answer.
I have done a capture and I see that there are NetBios SMB packets thet the ASA receives on inside interface, but apparently, the client doesn't receives these packets until 3 minutes later. I think anything else is happening thith the slow traffic for other applications.
My capture is:
1264: 12:15:12.870484 10.0.0.161.445 > 10.0.0.29.1140: . 777206108:777207368(1260) ack 837598730 win 5840
1265: 12:15:12.870590 10.0.0.161.445 > 10.0.0.29.1140: . 777207368:777208628(1260) ack 837598730 win 5840
1266: 12:15:12.870697 10.0.0.161.445 > 10.0.0.29.1140: . 777208628:777209888(1260) ack 837598730 win 5840
1267: 12:15:12.870743 10.0.0.161.445 > 10.0.0.29.1140: P 777209888:777210267(379) ack 837598730 win 5840
1268: 12:15:13.248964 10.0.0.29.1140 > 10.0.0.161.445: . ack 777208628 win 17640
1269: 12:15:13.249971 10.0.0.29.1140 > 10.0.0.161.445: . ack 777210267 win 17640
1270: 12:15:13.250124 10.0.0.29.1140 > 10.0.0.161.445: P 837598730:837598793(63) ack 777210267 win 17640
1271: 12:15:13.250643 10.0.0.161.445 > 10.0.0.29.1140: . 777210267:777211527(1260) ack 837598793 win 5840
1272: 12:15:13.250765 10.0.0.161.445 > 10.0.0.29.1140: . 777211527:777212787(1260) ack 837598793 win 5840
1273: 12:15:13.250872 10.0.0.161.445 > 10.0.0.29.1140: . 777212787:777214047(1260) ack 837598793 win 5840
1274: 12:15:13.250902 10.0.0.161.445 > 10.0.0.29.1140: P 777214047:777214426(379) ack 837598793 win 5840
I pass a configuration:
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 --.74.49 1
dynamic-access-policy-record DfltAccessPolicy
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
group-policy TunelVPN internal
group-policy TunelVPN attributes
dns-server value 10.0.0.9
vpn-tunnel-protocol IPSec
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
bwilmoth Fri, 12/05/2008 - 07:01
  • Silver, 250 points or more
Use the ping command to check the network or find whether the application server is reachable from your network. It can be a problem with the maximum segment size (MSS) for transient packets that traverse a router or PIX/ASA device, specifically TCP segments with the SYN bit set.
