Gilles Dufour Mon, 12/01/2008 - 06:30
do you want to probe /console ?
Do you want to match only /console ??
If the second, you need to create an http loadlabalcing class-map
switch/Admin(config)# class-map type http loadbalance UrlConsole
switch/Admin(config-cmap-http-lb)# match http url /console
Then under you http policy, match the newly defined class-map.
ropethic Wed, 12/03/2008 - 17:56
Create two class-maps
#class-map type http loadbalance match-any console
lb#match http url .*console.*
#class-map type http loadbalance match-any html
lb#match http url .*html
Create VIP
#class-map VIP-XXX
#match virtual-address x.x.x.x any
Create Policy Map
#policy-map type loadbalance first-match lb
lb# class class-default
lb# class console
lb-c# serverfarm "abc"
lb-c# class html
lb-c# serverfarm "abc'
lb-c# class VIP-xxx
lb-c# loadbalance lb
lb-c#loadbalance vip inservice
Apply to interface
int vlan x
service-policy input
shivgahlot Wed, 12/03/2008 - 19:24
Hi Ropethic
Thanks for your response
Your configuration is giving some logic, I will try then revert back to you.
I also tried with following configuration as shown below & but it doesn't work :-
class-map match-all EXTERNAL-VIP
2 match virtual-address tcp eq 7001
class-map type http loadbalance match-all URL-CONSOLE
2 match http url .*/console
policy-map type loadbalance first-match SLB-LOGIC
serverfarm Application-Farm
policy-map multi-match CLIENT-VIPS
loadbalance policy SLB-LOGIC
ropethic Thu, 12/04/2008 - 04:45
Dont forget to apply the service policy to the client vlan
