jasoninbtr Mon, 12/01/2008 - 05:51
I am assuming you mean the background image for the phone? Unfortunately there is no way to natively set this (help us out Cisco!). Here is a tool I have used in the past to push background images to phones.
http://www.voipintegration.com/software.html
It would be really awesome if Cisco had a configuration option for this under the Common Device Configuration.
Hope this helps.
Jason
Antonio Brandao Mon, 12/01/2008 - 07:43
Hi Jason,
Tks by your help.
But do you know if is possible change the ip phones logos in CME ?
Antonio
Rob Huffman Mon, 12/01/2008 - 09:29
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
