Router for Branch Office with PPTP Tunnel
Dec 1st, 2008
I am searching for a Router to connect a branch Office with 3 Desks to our Headquater via a PPTP Tunnel. The Router has to create the VPN Tunnel to our Windows Server based PPTP Server. The 3 Desks shall be able to access Headquaters Network through the Tunnel without establishing a VPN connection by themselves.
We have a A-DSL COnnection in the Branch Office with a DSL Modem where the Router has to be connected.
Which Router can be used for that? Is it possible with a CISCO 871?
satish_zanjurne Mon, 12/01/2008 - 11:35
Yes !!
You can use Cisco 871 it supports IPSec VPN with 3DES or AES.
It also supports Cisco Easy VPN Client and Server
HTH...rate if helpful..
wbecker_de Tue, 12/02/2008 - 00:33
Thank you Satish.
The VPN is not an IPSec VPN but a PPTP VPN Server. Can i create a PPTP Tunnel with the Cisco 871 as well?
Or do i use the Cisco Easy VPN Client for that?
