CME Remote Phone over Site to Site VPN
Dec 1st, 2008
I am looking to set up a Cisco IP phone at a remote L2L VPN site (192.168.50.0/24) to connect into our CME 4.3 system at our main office.
At present our Voice Network is using VAN10 with network 192.168.100.0/24 and our DATA network uses 10.0.0.0/24 on the Native VLAN.
Data Users have the Layer 3 switch (10.0.0.1) as their default Gateway so they can access the CME 192.168.100.0 Voice Network, similarly CME system uses the same Switch on VLAN20 as a default gateway on IP address 192.168.100.1, outgoing Internet is passed onto our Cisco ASA (10.0.0.2)
Can anybody tell me the steps involved in getting a remote IP phone up and running?
As far as I understand that I will just need to add the CME Server IP address as a DHCP option at the remote site and also add NAT Exemptions and Interesting traffic access lists for the VPN connection, is this correct?
Remote Phone---877w---Internet----ASA---Switch---CME Router
Many Thanks,
Chris
don-sullivan Tue, 12/02/2008 - 09:00
Use DHCP on the local subnet with option 150 pointing to your CME. If your using NAT you will also need add the exception. Interesting traffic will also be a must. The interface your ip phones are on will also need the following h323 added to pass correctly.
interface GigabitEthernet1/0.2
encapsulation dot1Q 2
ip address 192.168.x.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
[b]h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.x.1[/b]
