Cisco Unity 5.1 Failover
Dec 1st, 2008
I want to install the Cisco Unity 5.1 with exchange 2003 on MCS 7835. I will install Unity and exchange on the same MCS Server. I want to configure cisco unity in failover mode. Please let me know how to configure it. What are the software limitations. Is it require the same Hardware component because I will use MCS 7845 for failover. What are the license limitations.
Overall Rating: 4 (1 ratings)
Jaime Valencia Mon, 12/01/2008 - 09:42
  • Cisco Employee,
  • Hall of Fame,
    2011
look at the failover requirements and exchange requirements, if you want UM you cannot have Exchange onbox.
System Requirements for Cisco Unity Release 5.0
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html
Installation Guide for Cisco Unity Release 5.x in a Voice Messaging Configuration with Microsoft Exchange (With Failover Configured)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/installation/guide/vmexfo/5xcuigvmefox.html
Cisco Unity Licensing FAQ
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_qanda_item09186a0080094ce5.shtml
java
if this helps, please rate
Jaime Valencia Mon, 12/01/2008 - 12:54
  • Cisco Employee,
  • Hall of Fame,
    2011
indeed, but as i mentioned. not with UM.
this from the same doc i already posted:
Failover Requirements When the Message Store Is Installed on the Secondary Cisco Unity Server
•Cisco Unity must be configured as Voice Messaging. For information on the maximum number of subscribers supported in this configuration, refer to the Cisco Unity Supported Platforms List at http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_data_sheets_list.html.
java
Tommer Catlin Mon, 12/01/2008 - 12:57
  • Green, 3000 points or more
Opps! sorry I misread your UM statement in your first post.
mikram Tue, 12/02/2008 - 02:24
  • Bronze, 100 points or more
Waseem,
Are you trying to install Unity as unified message communication or just voice mail only? There are different sets to follow.
Cheers
Ikram
