BGP Mulihoming with 2 co-operate sites
Dec 1st, 2008
we have 2 co-operate sites. Each co-operate site has 2 different ISP's. Each co-operate site has an ASN number with /24 subnet. RIPE donot want to have 2 sites of the same company to have 2 ASN numbers. they have told us to to remove the ASN number on one site. As we have sites with 2 different ISP with dedicated link, we want to run the BGP so that we can take the beniefit of redundancy. How can we use one ASN number to run the BGP on these 2 sites?
your suggestion will be more helpfull.
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Mon, 12/01/2008 - 09:53
  • Hall of Fame,
    Founding Member
Hello Tauseef,
public AS numbers are becoming rare so the RIRs are very careful in assigning them.
You have two sites and each site is connected to two different ISPs.
Each site advertises its own /24 and this is fine a network of this size can travel over the internet.
I guess your two sites are not directly connected by any means otherwise implementation would be easy.
There is a trick to make the two sites communicate even if they use the same AS number:
on each eBGP session to the ISPs you need to add
neighbor isp-x-y allow-as-in 1
in this way the advertisement coming from the other site can be accepted and installed in the routing table
note: if you use prepending you need to provide as parameter the maximum number of times your ASN can appear on routes coming from the other side: you need to change the 1 to the number you need to accept routes in any case.
However, in the long term I would consider to buy an EoMPLS service between the two sites so that you can merge them and use your routing protocols over it.
If you do so you can advertise both subnets on both sites using other tools to make one site preferred for subnet A and one preferred for subnet B.
Hope to help
Giuseppe
lejoe.thomas Tue, 12/02/2008 - 02:26
  • Silver, 250 points or more
Thanks Giuseppe, didnt know about allow-asin
Lejoe
t4tauseef33 Wed, 12/03/2008 - 14:16
Thanks Giuseppe.
These 2 sites are not connected to each other through any way just the ISP connections.
lets say ISPA and ISPB are on site A and ISPC and ISPD on site B
ISPA ISPB ISPC ISPD
AS 50001 AS 50002 AS 60001 AS 60002
SITE A: AS 70001 SITE B: AS 70001
Can you give me a sample configuration for running the BGP in this case
ISPA Conneted router
neighbour ISPB-Local-Router remote-as 70001
neighbour ISPA remote-as 50001
ISPB Conneted router
neighbour ISPA-Local-Router remote-as 70001
neighbour ISPB remote-as 50002
ISPC Conneted router
neighbour ISPD-Local-Router remote-as 70001
neighbour ISPC remote-as 60001
ISPD Conneted router
neighbour ISPC-Local-Router remote-as 70001
neighbour ISPD remote-as 60002
how you will implement the allow-as-in? what is the change required on ISP?
Your help will be appricited.
Jon Marshall Wed, 12/03/2008 - 14:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tauseef
neighbour ISPA remote-as 50001 allowas-in 1
neighbour ISPB remote-as 50002 allowas-in 1
neighbour ISPC remote-as 60001 allowas-in 1
neighbour ISPD remote-as 60002 allowas-in 1
The ISP does not need to to change anything because the allow-as-in command allows an EBGP speaking router to accept an EBGP advertised route with it's own AS number in it. The ISP does not need to do this. Only you need to do it at Site A & B.
Jon
