Outdoor Antenna options for HWIC-3G-CDMA card
Dec 1st, 2008
The options I have found for these 3G cards is the the extension base that uses the Swivel Antenna (3G-AE015-R) and the ceiling mount (3G-ANTM1916-CM). Both of these are indoor solutions. The problem is that the building we are trying to deploy the cards in is a steel framed warehouse with a metallic exterior and the signal we get is poor for the 3G and CDMA2000 bands. Is there an outdoor mounting option for these cards? If we penetrate the roof we are able to get good signals on both networks.
For the HWIC-3G-CDMA-V , 3G Wireless WAN HWIC supporting -1xRTT, EVDO Rev A/Rel 0 (Verizon SKU) is supporting and HWIC-3G-CDMA-S , 3G Wireless WAN HWIC supporting -1xRTT, EVDO Rev A/Rel 0 (Sprint SKU) is supporting.
In addition to the Cisco 3G WWAN HWICs, Cisco provides a range of antenna solutions to accommodate a variety of installation environments. Here is the part number and description available.
Part Number Description
3G-ANTM1919D Multi-Band Swivel Mount Dipole Antenna, Faceplate Mount
3G-ANTM1916-CM Multi-Band Omnidirectional Antenna, Ceiling Mount
3G-AE015-R Single Unit Antenna Extension Base (15-ft cable included)
I hope it may help you.
scottmac Sat, 12/06/2008 - 06:38
  • Green, 3000 points or more
I'm unable to bring up the data sheets on the antennas you listed. But the basic descriptions appear to represent them as indoor-only.
Check these for outdoor use:
http://www.wpsantennas.com/omni-directional-dual-band-multi-band.aspx
Or, to be more general, "it's cellular" ... even an automotive cell phone antenna should work, as long as it has the TNC male connector (which most will).
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
