CSC disclaimer
Dec 1st, 2008
I'm not sure this should be posted here, if it shouldn't please tell me where.
We have an ASA 5520 working with CSC. We activated the disclaimer but it works in both incoming and outgoing SMTP mail. I would like it working just in case of outgoing mail, but can't find this option.
Does any of you know how should I do it?
Thank you very much.
solpandor Tue, 12/02/2008 - 03:59
hi
Are you using the CSC SSM module? If so, have you created the policy map and applied it to the inside interface? the policy map matches against an ACL so you could try that.
Ive got the CSC SSM to block incoming files uploaded via our web app and it works a treat.
