12-01-2008 10:31 AM - edited 03-15-2019 02:50 PM
It's not my idea, and I can't change this business model, but...
We have a single branch office that will soon be shared between 2 different holdings of ours. We have a single PRI with an H.323 gateway registered to 2 different CCM clusters.
I'm concerned about how we're going to maintain voicemail functionality in SRST fallback. 1 group of users is using CUE while the other is using Unity.
I'm wondering if I can do something clever with COR lists -- specifying DID ranges under SRST via cor outgoing statements, then have 2 preferenced outbound dial-peers - 1 for Unity and 1 for CUE. Then within the 2 outbound dial-peers (both with the SRST voicemail # as the destination-pattern), I can do some digit manipulation to adjust the voicemail # to either CUE or Unity. I'm not 100% sure if a call hits a dial-peer with a cor list applied and access is restricted...does the call hunt to the next preferenced dial-peer with the same destination-pattern.
I'm not sure how much sense that makes, but if any other information is needed just ask. Also, if anyone can see other potential gotchas/issues besides SRST vm, please mention that also.
cheers,
Will
12-24-2008 09:53 AM
I'm hoping if I phrase this a little more succinctly then I'll get an answer. ;)
Question:
If a call hits a dial-peer with a cor list applied and access is restricted...does the call hunt to the next preferenced dial-peer with the same destination-pattern?
thanks,
Will
12-24-2008 04:09 PM
Hi Will,
Yes it will. The nature of corlists would break if this didn't occur.
Using corlists is about the only way I can think of doing this. When you have SRST ephones your options for voicemail are limited.
hth,
nick
12-29-2008 06:56 AM
Cool! Thanks for confirming. I was out of ideas if this wouldn't work. I have a spare ISR I could put out there, but would be a waste.
Happy Holidays,
Will
