Any way to avoid losing configuration when downgrading code?
Answered Question
Dec 1st, 2008
I downgraded a 4400 from 4.2 to 4.1 and the configuration was lost. The release notes mention that this "may" happen. Does anyone know if there is a way to prevent it?
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn411850.html#wp233850
"If you require a downgrade from one release to another, you may lose the configuration from your current release. The workaround is to reload the previous controller configuration files saved on the backup server or to reconfigure the controller. "
Correct Answer by Scott Fella about 8 years 2 months ago
Overall Rating: 5 (1 ratings)
dziminski Mon, 12/01/2008 - 12:37
Thanks! Then I should be fine down-grading from 4.1.x to 4.0.x since both have binary config files?
Scott Fella Mon, 12/01/2008 - 12:48
Yes... always make a backup, so all you would have to do just in case is enter the information on the startup wizard and then upload configurations.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
