1600 Router
Dec 1st, 2008
I have to reload the Router to factory defaults, but I keep getting this error and cannot do anything.
00:00:09: SERVICE_MODULE(Serial1): self test finished: Passed
00:00:20: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
00:00:20: %LINK-3-UPDOWN: Interface Serial0, changed state to down
00:00:20: %LINK-3-UPDOWN: Interface Serial1, changed state to down
00:00:21: %QUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
00:00:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed sta
te to down
00:00:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to down
00:00:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state
to down
00:00:22: %SYS-5-CONFIG_I: Configured from memory by console
00:00:22: %SYS-5-RESTART: System restarted --
IOS (tm) 1600 Software (C1600-Y-L), Version 11.3(5)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Wed 12-Aug-98 04:15 by ccai
00:00:23: %LINK-5-CHANGED: Interface Serial0, changed state to administratively
down
00:01:21: %QUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?
How do I get in to reload the config file to default?
Tamra
John Blakley Mon, 12/01/2008 - 12:59
  • Purple, 4500 points or more
wr erase
Is that what you're doing?
John
Richard Burts Mon, 12/01/2008 - 13:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tamra
From these messages I would assume that there is not anything connected to any of the interfaces. Is that correct?
Not having anything connected to any interface should not impact your ability to manage the config file. After the router goes through these messages, if you press the Enter key (perhaps a couple of times) do you get any response from the router?
Rick
