How to change MOH audio source without resetting devices
Jaime Valencia Mon, 12/01/2008 - 14:31
unfortunately changes that ask you to reset the devices are because a config file has changed and they do not download the files unless they go thru the reset process
it's not just because, you need to reset the devices as instructed
java
if this helps, please rate
