sjones226 Tue, 12/02/2008 - 08:20
Thank you, Syed! While this data sheet contains max concurrent connections, it does not contain a measurement for connection per second or flow per second. For instance, the ACE 4710 and ACE module offer 120,000 and 325,000 connections per second, respectively. I'm looking for similar info on the CSSs. Thanks again.
Steve
Syed Iftekhar Ahmed Tue, 12/02/2008 - 17:05
  • Blue, 1500 points or more
From my notes
L4 conns/sec
CSS11501 -- 7,500
CSS11503 -- 22,500
CSS11506 -- 45,000
L7 conns/sec
CSS11501 -- 3300
CSS11503 -- 10,000
CSS11506 -- 20,000
SSL throughput
CSS11501 -- 245 Mbps
CSS11503 -- 490 Mbps
CSS11506 -- 980 Mbps
The total number of entries in the CSS sticky table depends on the size of
the CPU memory.
� The CSS 11501 supports a 128K sticky table (288 MB of CPU memory).
� The CSS 11503 and 11506 supports either a 128K or 32K sticky table,
depending on whether the System Control module (SCM) has 288 MB or 144 MB of
memory. With 288 MB of memory, the CSS supports a 128K sticky table. With
144 MB of memory, the CSS supports a 32K sticky table.
Syed
sjones226 Tue, 12/02/2008 - 21:29
Wow, thanks again Syed. Would you mind providing the references? If unable, I understand. I assembled such stats a couple of years back for another client when comparing CSS to ACE. I think I even had to involve TAC as they weren't so readily available. I no longer have those notes. Thanks again, and happy load balancing!
tamtan Thu, 12/11/2008 - 01:37
  • Cisco Employee,
Hello, I would like to enquire on CSS11501: what is the latency/propagation delay for this product? I can't seem to find it in our intranet.
