Equipments for T1 link
Dec 1st, 2008
We have a site that is connected through fiber to the main office, we would like to create a backup link for a group of user (on a specific switch) to be able to connect to the main office through a T1 line if the fiber was accidentally damaged. What equipments do I need to finalize the connection on switches of both sides. Is it only CSU/DSU on both ends or do I need to have routers? if so what kind do you recommend?
Thanks for your help.
vassiliev Mon, 12/01/2008 - 19:18
Em...Can you install T1 module on your current router? You can use T1 to backup your fiber.
Best Regards
Cheng
durga_suji Tue, 12/02/2008 - 01:26
a. backup link for a group of user (on a specific switch)
You can create a access list for this specific group of users to be connected over T1 line, in case of failure.
b. What equipments do I need to finalize the connection on switches of both sides.
If the router doesnot have support for WAN modules, you will have to go for csu/dsu for T1 connectivity.
regards
Wajma_2 Tue, 12/02/2008 - 08:39
Thank you for your response,
I have all the users who need to have a backup link on an HP switch, the switch will be up linked to main switch (has fiber link to the main site) and also to a backup link through T1.
Now I have two CSU/DSU, my question is do I need any other equipment between HP switch and the CSU/DSU, or between the CSU/DSU and and Cisco 6509.
